This curious happening...
ericnliz
Member Posts: 4,437
Went out to the WOLFTA@B today, and was doing some general check-over when I looked out the driver's side widow and noticed the seal around the window was sagging about mid-way. I tried to see if it would just "push" back into the rail above, but would not. Just wondered if anyone else has had this issue, and if so how to fix. Any thoughts? It's not terrible at this point, but I don't want it to get worse either. Thanks for any input!
Eric
Eric
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf
Eric aka: Lone Wolf
Got a pic?
Haven't heard of that happening before.0 -
PXL, No, don't have a picture. Right now I've got the A/C on because it's like 110* in the trailer. I'm going to wait until things cool off a bit, and take a closer look. I'll keep you informed, thanks.
Eric2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
PXL, After getting the interior heat down below 80*, I opened the window all the way. It appears that something, either the rubber window gasket [black] had expanded, and / or the window frame. I used the round handle end of a plastic paint scraper to gently maneuver the seal back in to place. It had come out of the groove surrounding the widow where the gasket fits in to the lip. Pretty easy fix for anyone else having this problem, just let it cool off a little before trying as the gasket had expanded from the heat, and would not allow it to remain in the groove. Thanks for trying to help!
Just a note, I'll let you know if it was a permanent fix, or a re-occurring thing.2016 T@B MAX S-aka: WolfT@B
Hopefully permanent. Keep us posted - If it happens again, take a quick pic so we can see where and how deformed.0
boo, the seal fits into a groove around the window. It needs "room" to expand and contract with the weather conditions. The only thing I can figure out at this point is that it wasn't fully seated to begin with, and that is why it drooped in just one spot [ about 3" long].As soon as I got it back into the groove, it stayed. Like I said in my previous post, we will see if it happens again. Thanks for the hint though, might be helpful in another area.2016 T@B MAX S-aka: WolfT@B
@ericnliz, do you leave your roof vent open while not camping. My thermometer shows it got up to 101*F one day inside my T@B and that was with the roof vent open. Maybe the heat buildup had something to do with the window trim expanding?Verna, Columbus, IN
Verna,
Yes, I leave the roof vent open when I'm not camping about 3 to 4". I just went out and checked the seal again as it is about 90* were I live right now. It is still in place. Like i mentioned to boo, I don't think that small area where it started to come down was fully seated in the groove it is meant to fit in. I'll still keep an eye on it, and I checked all the other windows [passenger side and front] and saw no issues with those at all, soooo the mystery remains a mystery because it has been hotter than this previously and I didn't notice it bulging before.
Eric aka: Lone Wolf2 -
I've got a pic for you, it happened to me yesterday and that's why I'm here trying to figure out why. It wasn't even hot, in the 70's but humidity was high. I didn't know you call this rubber piece a gasket and secondly I thought I was going to need to seal it back down. Learning a lot! Thank you!0
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
