Microwave installation
planobenz
Member Posts: 18
I have a Sofitel Max S on order with factory pickup. The one handy thing that is missing is a microwave (only $29 from Walmart). Would like to give the factory a little challenge to install a small .7 microwave (17.30x13.40x10.20) under the sink or replace the middle cabinet in the rear. The mount I guess would be similar to the AC.
Since I don't have a unit to measure and/or determine functionality, any ideas or suggestions would be helpful as I work with factory on this.
Plano TX, 2017 T@B S Max Sofitel, 2017 Honda Ridgeline
I have the Westinghouse 700W countertop model. It's approximate dimensions are 18" wide x 10" tall x 11" deep (up to the door seal. 14" deep with the door handle). It weighs 21 pounds. You'll need a 110V outlet nearby for the cord. You'll also need an inverter if you plan on using it off-grid. This microwave actual pulls 900W while running.2016 Outback 320
2024 Ford F150 Supercrew short bed.0
- 120 Dutchman and Vintage TaB Archives
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
