With all the Alde posts, I'm surprised my Alde gurgle search comes up nil!
We had Alde problems develop this spring and had warranty work done. We've used the Alde for hot water this summer and it's worked well. Now we're camping in the chilly mountains and the Alde heats well but the glycol reservoir gurgles loudly whenever it is running. (This has no relationship to the earlier Alde issues.) I don't think it was this loud last fall. Maybe I have one of the many valves under the seat positioned wrong?
I hope to avoid the multiday trip to the nearest Alde certified shop!
Thanks for any insight.
Doug
Des Moines Iowa
2016 S Max Sofitel
0 ·
Check your glycol level and make sure it's in the margin - seems to be louder if you're low. BUT, the gurgling is always there. Bothers some more than others. Since I'm full-time, I have the gurgling half the year so it's just one of those background noises the brain learns to filter out.
If you don't use it enough for the brain to finally ignore, I recall someone wrapping some fiberglass insulation around it (the reservoir) to deaden the sound.
Your problem could be a fluid level issue or it could be that the pump flow might need to be adjusted/regulated or as Frank noted above, due in part to issues related to higher elevation use.
Thanks for the quick responses.
The glycol is fine, so now I should check the pump setting. do you have a diagram or picture on this devise? Also, along with the roaring at high alt using propane it also had "gas failure", so it would turn itself off 3 times though the night.
