3M Command Strips
Anyone else having a problem getting the strips to hold on the walls of your T@B?  I treated the wall with rubbing alcohol first as recommended and then attempted to hang a very, small lightweight clock, but the clock kept falling off along with the strips.  I thought command strips were a RVer's best friend!
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
  • Nomad
    Nomad Member Posts: 7,209
    No problem here - Have them holding things in several places - Haven't had any come loose in two years now.
  • Ratkity
    Ratkity Member Posts: 3,770
    The strips don't handle heat and bouncing well, so I make sure anything that's more than a few ounces are placed elsewhere until I get to my destination. Also note that some strips are only rated for certain weights (1 lb, 5 lb, 10 lb) when used for picture hanging. I usually get the heavy duty ones.
  • Nomad
    Maybe mine have worked well because I avoid the extremes - heat/cold.
  • Tabaz
    Tabaz Member Posts: 2,420
    Someone on this forum had a problem with the command strips pulling the interior finish away from the wall substrate, causing a bubble behind the command strip. Since reading that post, I never use them on the interior walls (just on wood surfaces).
    2016 Outback 320
  • SweetlyHome
    SweetlyHome Member Posts: 336
    edited October 2016
    We have had issues with Command strips coming loose in our T@B as well.  Normally in very high temps.  We take anything on Command strips down when traveling.
    I was interested and I found their website http://http//www.command.com/3M/en_US/command/.  This had a load of information including detailed instruction / spec sheets for their products.  What is notable is the recommended temperature range for the standard medium type strips of 50° to 105° F.   I know the inside of my T@B gets warmer that 105 stored closed up outdoors in a Florida summer.  The say the outdoor versions "Holds strongly from -20°F to 125°F" so this is what we will use in the future and see how it goes.
    Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
  • Photomom
    Photomom Member Posts: 2,217
    I had this happen in one spot when I left something hanging on a command hook on a very hot day. The hooks that weren't being used were fine. I make a point of taking things off the hooks when we're on the road or when the trailer is sitting on the driveway and have had no further problems.
  • ChanW
    ChanW Member Posts: 3,168
    Hmmm. I'm sorry to hear this about Command Strips - I just decided to try them!
    Looks like we'll need to hunt down the 'outdoor version'...
    We had a problem with the interior wall's 'skin' bubbling, when we used a suction cup type of hook on it.
    Chan - near Buffalo NY
  • Tabaz
    Found the post - "Wall Paper Bubble Issue."  Pretty scary story.  Right before Halloween and all.
    2016 Outback 320
  • Verna
    Verna Member Posts: 6,876
    I've had no problem with the Command Strip Velcro on the walls. I have a key holder that I always have at least one flashlight attached to and it is fine.
  • Smullis7
    Smullis7 Member Posts: 221
    I haven't had problems on the walls, but I tried using them for a small shelf attached to the mirror in the bathroom...it lasted @ 3 showers and came down.  I think that was more to do with it not being waterproof.
    Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
    M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
  • Dalehelman
    Command makes a special strip for shower use. They come with the shower bins sold at Walmart in the bathroom department.
    1. Hash  T@B Fun
  • SweetlyHome
    Command has at least 3, maybe more, types of strips listed on their website: standard, outdoors, bath/shower, etc.  Specs for outdoor and bath/shower look similar with higher temp ratings and water resistance.  Haven't compared prices.
