CS-S CLAM SHELL DOOR DAMAGE
gulfarea
Member Posts: 524
After a 3,200 mile trip this summer I noticed this only on the right side. The screws on the left side were put in straight & flush so no damage there. If the screw goes in at an angle it sticks out just enough to do this & stops
the rubber seal from sealing properly. I will send this to them so they can correct the drill angel & make a great camper even better. I do not know the correct torque bit size for the screw. The two I have do not fit the screw & will have to get one. Art
the rubber seal from sealing properly. I will send this to them so they can correct the drill angel & make a great camper even better. I do not know the correct torque bit size for the screw. The two I have do not fit the screw & will have to get one. Art 2019 TaB 320 S Boondock Edge
- 915 Tips & Tricks
