Crazy Question: Can a front window be added by factory?
I keep seeing photos of the T@B's with front windows. When I bought mine it wasn't common, and the sales person dissuaded me. I really like my stainless steel backsplash, but was wondering if it was even possible for the factory to add a front window to my 2013.
  • Nomad
    Nomad Member Posts: 7,209
    Don't quote me but I seem to recall that the answer is no. Think there's a different substructure required.
  • AldebaranJill
    AldebaranJill Member Posts: 478
    Hmmm, maybe they need beams in different places or something. I'll keep my fingers crossed to see what others say. I wonder if there's another size window that would fit within the existing substructure.
  • Nomad
    Hard to find curved windows so I wouldn't hold out hope for another sized one.
  • Verna
    Verna Member Posts: 6,876
    The factory's answer is no.  Search the forum as a couple of other people have asked the factory and the answer is no, the proper support has to be initially built into the front wall.
  • Photomom
    Photomom Member Posts: 2,217
    Verna is correct. We looked at a nearly new T@B that would have been perfect for us but it didn't have a front window. I called the factory to see if one could be retrofitted and they said no, they don't do it. The guy said they were aware that some people had done it themselves but they discouraged it.
  • Tabaz
    Tabaz Member Posts: 2,420
    The reason it's a bad idea is there is an aluminum frame that supports anything structural in the walls and ceiling (i.e. the ceiling fan opening, entry door and each window - not to mention the A/C unit).  Somewhere on this forum are some photos taken during a factory tour that showed the aluminum framework.
    2016 Outback 320
    ScottG Administrator Posts: 5,674
    I was thinking of those same photos. I can't seem to find them, but I think they came from @Cyclonic.
    Cyclonic, can you redirect or repost? I'd like to have the photos in the event I ever install the Outback rack. Thanks!
  • AldebaranJill
    Got it, makes sense. I wish the sales person had told me this decision was something I could not reverse later. At least now I can stop wondering. Does the porthole window have the same framework around it?
  • Nomad
    edited December 2016
    1.jpg 43.4K
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Looks like @PXLated found it :grin:
    I have done three tours, they can be found on my photo site, cyclonic.smugmug.com, under Our Adventures>Tours
    Sterling, VA
  • Verna
    @AldebaranJill, knowing that the side walls are created with aluminum frames in the correct spots for windows or A/C, etc., the port hole would also need support to keep it in place.  If the support isn't in place, the window can't be installed.
  • AldebaranJill
    Thanks everyone! I can now stop wondering if it is possible. If I want to see out the front will just have to install a peep hole or video camera.
  • AldebaranJill
    Wonderful resource, thank you!
