Alde 3010 Digital Thermostate External Start Setting
Smullis7
Member Posts: 221
Does anyone have the external start option on their Alde? I can't find any explanation or instructions for it. The manual doesn't even show it. I thought I had turned off the Alde. When I went to put something in the T@B, I noticed the Alde was still generating heat. The only thing in an 'on' position was the 'external start' (I turned it off now). I just want to know what it does and why I should have it on...
Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
There is a very small green light in the power button on the lower left of the control panel. If it's out, the Alde should be completely off.2016 Outback 320
2024 Ford F150 Supercrew short bed. -
It was out. The thermostat was turned off. I had also set the electric and gas settings on the main screen to off...but the Alde was still producing heat. The only setting that was set to on is the external start pictured above. I just can't figure out the point of it or any documentation explaining it.Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
My External Start menu page looks just like your photo. My power button switch green light is off and the Alde is complelety off (per my battery monitor). Sounds like something wrong with the Alde.2016 Outback 320
As I understand it, the external start allows the Alde to run without the control panel being on (DC power has to be on). You must set the parameters (temp/etc.) before turning the control panel power off.
When External Start is OFF, the Alde only runs when the control panel is on
When the control panel is OFF and External Start is ON:
EXT = an external contact closure (switch) turns the Alde on
120V = whenever 120V power is available the Alde turns on2016 Max S, 2011 Volvo XC60
Seajeeper, that sounds exactly like what I've experienced since I do have it plugged in to shore power and External Start was on! Thanks! I'm still now sure what the point of it is since if I wanted the Alde to run...I'd turn it on. At least I know what it does now. Thanks again!!Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
I had this problem this morning. I had set my heat to 75° dry camping, using propane for heat. It was 57° inside this morning when I woke up! The control panel said ext was shut off or I wouldn't have had any idea how to correct this. When I turned it on the heat came on & is working fine. So that's why I would want the ext on, lol.
Btw, since the heat is up to 73° now (set at 75°) I thought I'd experiment. I turned off the ext and the heat is still on even with the control panel off it seems to be on when I turn the panel back on unlike this morning. Any idea why?2018 T@B 320S / 2024 Chevy Blazer RS AWD / Phoenix, AZ
