Fuse (30 amp) keeps blowing at the inline battery 2017 outback
emgman
Member Posts: 5
I've had my new Tab outback for two weeks . I took it camping 4 days last week. When I got it home I went inside to and found that nothing would power up.....everything was dead which surprised me because I thought the battery would charge up on the 2.5 hour drive back home and all the running lights and turn signals on the trailer worked fine as I drove home. . So I hooked up the shore power but everything was still dead. I looked at the breakers and fuses under the drivers bench seat and noticed the 15 amp breaker was flipped off. I flipped it back on ..still no power to the tab. I pulled out the 30 amp fuse on the converter box and lo and behold everything came on. Went to the tongue and opened the propane and battery box and checked the in line battery fuse.... it was blown. No problem. Went to radio shack and got 2 fuses got back home and put one in...it blew immediately. Put the 2nd on in . It blew immediately. Any thoughts as to what I'm doing wrong or what could be wrong with the outback? Thanks.
Dropping it off at a service center this afternoon...there's obviously a short somewhere but I don't have the ability to figure that out right now so the outback is going to the experts. Thanks anyways.
Edited: Never mind. Just saw you stated your inline IS 30amp. Hope it gets sorted today!Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.
You did the right thing; if a fuse blows immediately, there must be a short somewhere. Bet it's a couple of wires chafing together that wore through the insulation as a result of your trip. Hope they find it!
Mine was blowing similar to that - when I connected the seven-pin to the TV it would immediately blow the 30 at the battery. Turned out the wiring to the seven-pin was strung to close to the exhaust and had finally burned thru and was shorting out.
Good luck
- 915 Tips & Tricks
