I want to mount the tire to the tongue/frame - have seen pictures where people have done it - but am having trouble finding a mount that will fit. The ones I've found so far fit (up to) a 4" frame but my T@B is 4.5".
Can anyone that's done it tell me where they got the bracket?
TIA
This is the one I used. There are probably others out there.
http://www.etrailer.com/Trailer-Cargo-Control/Fulton/FHDSTC0101.html
Happy Trails Y'all
I seem to recall having to add a washer or two because the bolts supplied were a bit long. I think someone else who used this mount said theirs came with two different lengths of bolts, but mine did not. If I had ready access to shorter ones, I would have used them. I think the mount was designed for trailers with wider/thicker rails. Not really a big deal since the bolts extend inside the tongue. I was able to mount it with the hardware that was included. I mounted mine on the passenger side as close to the LP/Battery cover as I could get it and still have it not interfere with anything. I chose this mount because it extends the tire out away from the tongue a bit and allows you to mount if further back. When it stops raining, I could take a couple photos if that would be helpful.
Happy Trails Y'all
Hi all.
My wife and I are new to the forum and new owners (in the Seattle area) of a 2007 T@B and have been on two outings so far. We are still going through the getting-to-know-the-T@B stage. We noticed that the spare tire is mounted under the body and is hard to get to. I didn't want to unscrew the mounting nut for fear of breaking my arm when the tire falls down. So, I too am interested in mounting the tire elsewhere. However, in your mounting the spare on the tongue, has anyone noticed much of an impact on load on the tow vehicle due to increased tongue weight? The original mounting location is close to the axle and doesn't cause any tongue weight. Comments?
Happy Trails Y'all
