What do you do with your Lagun Table when the bed is setup
BirdieJane
Member Posts: 237
We find dealing with the Lagun Table, while setting up the bed an UN-enjoyable routine, What do others do to make it easier? Where do you put your table when the bed is setup?
2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn
I replaced our tabletop with a solid piece of wood and cut it the right length to replace some of the bed slats at night if we want.
James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback2 -
Our Lagun table top also does double duty as a bed "slat." Fills up about half the space and I made two more half size matching "slats" to fill remaining space. Half size allowed us to stow them away easily...see photo.
It is still a bit of a process to remove from pedestal, mount pedestal on bottom of table, and put in place for bed...but better and lighter than table that came with ours in 2016.
Kim & Mary Kay, 2016 CS-S, Spokane, WA
Ours is a 2017 sofitel max s. The table is usually outside ready to use or has a microwave on it while we are camped. As a post script, ours came with the outside mount and a full set of bed slats.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Depending on which table top you have, it may fit in the top of the front passenger side bench. Someone had a picture here. It rested nicely on the rim that supports the lid.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The outside mount really does get it out of the way. You can use a Walmart table inside, too.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
My table is in the shed. Never use it....got tired of it getting in the way.....plus I don't spend time in the t@b unless I'm sleeping.0
We leave it on a lagun bracket mounted outside most of the time with our convection toaster oven when camping. But it fits perfectly in the top of the passenger side wheel well compartment.
2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.2
