Front window
clinck
Member Posts: 57
i just purchased a 2014 320S.. No front window.. Is it a possible to have that installed? Either by the factory or a dealer with that capability?
sure can appreciate the light that another window affords.
Chris and Toby, the wonder dog
2014 320S
2016 kia Sorrento SXL V6
2014 320S
I could make the trip to sugar creek as I have family in Ohio.
2014 320S
2016 kia Sorrento SXL V60 -
No, it's not possible because the aluminum frame needs to be built in before the T@B is built.
A search of front window brought up this thread. I know RZRBUG also looked into getting the front window on his T@B.
http://tab-rv.vanillaforums.com/discussion/comment/55157#Comment_55157
#RZRBUG
Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.4 -
Does the porthole require a frame? It seems to have it's own built in frame.
Seattle, WA -> Palm Springs, CA0 -
The porthole would be a good question to ask nüCamp.Verna, Columbus, IN
The porthole can be installed. Saw PV install one at Tearstock last year.
Sterling, VA1 -
They installed the porthole in my 2015 T@B Max S.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ2
The front wall is curved. I've only seen pics of the porthole window on the flat side wall.John and Henrietta, Late 2016 T@B S Max in Western New York0
I know it's curved. But given the beams are 8" center to center going across, it means that you could, in theory, install a smaller window that was in between the beams, running horizontal. I've been shopping for port hole light windows. If you lay a piece of something flat against 6" in the front surface, you'll see the gaps are very small. I am still investigating adding a window in the front. It's a matter of finding the right window. Here's the concept:Photomom said:The front wall is curved. I've only seen pics of the porthole window on the flat side wall.
