Front window
i just purchased a 2014 320S.. No front window.. Is it a possible to have that installed? Either by the factory or a dealer with that capability?
sure can appreciate the light that another window affords.
Chris and Toby, the wonder dog
2014 320S
2016 kia Sorrento SXL V6
  • clinck
    clinck Member Posts: 57
    I could make the trip to sugar creek as I have family in Ohio.
    2014 320S
  • Verna
    Verna Member Posts: 6,876
    No, it's not possible because the aluminum frame needs to be built in before the T@B is built.
    A search of front window brought up this thread. I know RZRBUG also looked into getting the front window on his T@B.
    http://tab-rv.vanillaforums.com/discussion/comment/55157#Comment_55157
  • RollingLagrima
    RollingLagrima Member Posts: 435
    #RZRBUG  <3
  • AldebaranJill
    AldebaranJill Member Posts: 480
    Does the porthole require a frame? It seems to have it's own built in frame.
  • Verna
    The porthole would be a good question to ask nüCamp.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    The porthole can be installed.  Saw PV install one at Tearstock last year.
    Sterling, VA
  • Michigan_Mike
    They installed the porthole in my 2015 T@B Max S.
  • Photomom
    Photomom Member Posts: 2,217
    The front wall is curved. I've only seen pics of the porthole window on the flat side wall.
  • AldebaranJill
    edited June 2017
    I know it's curved. But given the beams are 8" center to center going across, it means that you could, in theory, install a smaller window that was in between the beams, running horizontal. I've been shopping for port hole light windows. If you lay a piece of something flat against 6" in the front surface, you'll see the gaps are very small. I am still investigating adding a window in the front. It's a matter of finding the right window. Here's the concept:
