Tapping "Reverse Light 12v Power"
I have been thinking of installing a rear view camera too. They have one that fastens onto the licence plate mounting bolts and is powered by the licence plate light light. This would be useful for seeing traffic behind while driving as well as reversing.Ray and Vida Barrick
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada0 -
That description fits the one I have. (Tada Wireless) I wish to use the backup light power as I don't want the camera broadcasting (its wireless back to the monitor in the TV) whenever there is power to the taillights (or license plate light). I could use the taillight or license plate power and just turn off the monitor in the truck so I am not distracted while not backing up, but prefer not to broadcast a wireless signal needlessly as it could cause radio uinterference...)
I could easily get the wire from the camera to the wiring area near the fuse box. I just don't know where the "backup light power" terminates or if it enters the trailer envelope at all. I'd hate to run a second wire back to the TV...
On a 7 wire rv plug,reverse is your center pin
If you take your plug at your trailer,take that apart and check the color of the wire,there is a chance there is not a wire hooked to it in the back of the plug. The cable coming from that plug may only be a 6 wire cable, in that case you will need to run a separate wire to that center post.0 -
I was hoping they ran a full Seven Wire Harness back inside. I fear taking the trailer end (female side) apart will be a problem. I will run out tomorrow and see if I can get into the plug. Thanks for the tip.
If the lead is terminated at the TV,(trailer plug sealed with no way in), I'll use the license plate lead and just turnoff the monitor so I am not distracted when not backing up.
oh and thanks Matt!0
The pictures I've seen show it as a yellow wire.Norm & Pat. 320 S Outback Utah or somewhere else.
Frankonsand - Could you post a pic or some info on that license plate backup camera - Haven't needed one so far but could come in handy at some point - Thanks0
I am curious if the wireless signal will reach from the rear of the T@B to the front of the TV. I was thinking of doing something similar but wondered if the range was good enough.Martin - Trailer name: James T@Berius Kirk0
Frankonsand - I'd vote for the license plate lead. I know when I had a 36.5' motorhome that backup camera came in handy in passing situations to verify I'd cleared the passed vehicle, and also to check if our convoy was in place. I'd just leave the monitor off until I was in a situation where I thought I might need it.
- gcw
gerry - Flintstone, GA - 2015 T@B S - 2012 Toyota Highlander0 -
Mawebb- I tried a little test. I hooked the camera up to the tab battery siting inside my shop on one of my work benches. I then hooked the yada wireless monitor up to the tv and got a picture of my shop. The camera was about 18 feet away from the monitor/ receiver. I then backed down the driveway, got about 50 feet away before the picture momentarily disappeared. I backed to about 60 feet away before I lost the signal entirely.... My guess, the wireless transmission won't be a problem..1
Here's a plug diagram if this is what you are looking for....
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Thank you Mike.0
