Markath, here's the post I did on the single lever faucet change out.
finally finished the shower faucet upgrade. I chose the American Standard Stratton Shower faucet
( $74.00 from Menards) , It was the only one I could find at the local big box
store that allows you to adjust the flow rate by moving the handle upward or
downward and the temperature left to right. So once you have the water temp set
you can shut off or adjust the flow
without changing the temperature. The fitting I used to attach the handheld
shower hose is a wall elbow from Delta part
#50560 ( $23.11 from Amazon). Thanks for the idea Dale, we are really
going to like this upgrade.
sorry about the view on the last pic
I almost didn't see your question!!George101 said:Ratkity said:They have a tendency to break. I have more than one on hand. My popup ate them for breakfast lol.
Where do you get them and how do you replace them?
So it will unscrew from the faucet side without taking the faucet apart?Ratkity said:I almost didn't see your question!!George101 said:Ratkity said:They have a tendency to break. I have more than one on hand. My popup ate them for breakfast lol.
I have an RV parts place 5-6 miles away from my house and got them there. I'm sure you can get them on Amazon.
How to replace? Easy, they are only plastic and with plastic threads, you screw it on a smidge over finger-tight. There wasn't even any teflon tape. Shouldn't need it with plastic threads. Careful not to cross-thread the little suckers (pun).
