Thanks Norm as I wasn't aware of this..... That probably explains things and I fired off a note to the factory asking for an explanation. I'm guessing that people should be good to go with the Al-KO axles and will receive great service should an issue crop up.normfun said:My 2015 tab CS-S has an ALKO axle. The factory must be using a use up and go to inventory system. No problem though as I believe Dexter just purchased Alko.
Normfun, I had a heck of a time I live in an HOA neighborhood and couldn't leave the T@B in the drive so I went to salvage yards looking for a used rim and they wanted $30 and up. I checked on EBay and they had them for $15 each plus $14 shipping so I bought new ones on EBay vs used ones at a salvage yard. (Remember it's 5 on 4.5" lug size for the T@B). I then took the rims to a welding shop that had a Plasma Cutter and they cut the flanges off pretty as you please and the trailer fits in the garage without even taking the top seal strip off of the outside garage frame. Now, the T@B sits in the garage, clean, no hail or storm concerns and, I don't have to winterize it because the garage never gets below freezing-plus it is has electricity and the grandson and I are going to speed in it one night when he is here. I even tried out the Alde system and it takes about 1/2 hour to heat the T@B. To me it was worth $60-70 to buy the rims and place it in the garage. I looked into covered storage and it was $85 per month so over years time, we will receive many times the cost of rims and cutting them down vs storage fees. Let us know if you do the rims, more people are interested and I like to see other people figure out the details that aren't mentioned in the manual.normfun said:Sgtjohn You mention your trailer being 2 inches off the ground???? Did you remove the wheels and use something to get it in the garage? Just wondering as our trailer is about 6inches too tall to fit through the door.
So which is the better axle? Germany used to excel in their products and perhaps still do-I'm not sure. But I like the idea of being able to grease the bearings thru a zerk. Many, many years ago as a foolish teenager I remember I had an old Ford and the front end began squeaking and after a few miles the entire wheel spindle came off with the wheel and the Ford hit the dirt. Another time when I was going on leave in the military at 3 AM the little Rambler began squeaking from the front end and I stopped a felt the grease cup on the front wheel and it was hot. Luckily I carried a can of grease in the trunk and tools so I took care of the problem and was on my way. It is vital that the hubs are greased on any vehicle, disaster can occur.mash2 said:It's interesting that the rated capacity of the Dexter axle is 2,200 pounds while the Al-ko is 3,000....
