Running lamp circuit
4ncar
Member Posts: 1,072
is there a inline fuse for just the running lights? I have brake & turn lamps but no running lamps. I have “Juice on the tv 7 pin...
2018 320S Outback
2018 320S Outback
Have to ask, is this only with your new car?T@B trip wherever
New surprises everyday
See beautiful world0 -
Well, yes, but haven’t hon so far is hooking up the old again...guess im gonna try, now that u ask...where u going with this?TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
New Jeep is wired differently!!!!TV- '16 Chevy Colorado LT Crew Cab-DuraMax
Maybe something is missing in the wiring; relay, trailer flasher, fuse... Someone with the same car should be able to help (or there is always the dealer).
( Jeep Grand Cherokee Summit 3 L diesel) T@B trip wherever
Dealer(boooo) lol. I get battery at the fuse box, replaced fuse no good. I loothe the idea that the Perez is a break in the wire from the fuse box to the 7 pin on the TV. Got a buddy who's a mechanic with more patience then me coming by today to take a peek...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
I hate to even admit this but I thought I had trouble with the running lights on mine a few weeks ago. The Jeep Cherokee has the knob for the headlights right in line with my left knee and I didn't realize that my knee had turned off the headlights. Because I was only driving during the day, I didn't notice. Without those, the running lights were not powered. Now I know!2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX1
I believe I have found the culprit. As there was no power at the TV 7 pin, but I have power at the fuse box, it HAD to be wiring from fuse panel to 7 pin. I just couldn't believe it to be on a 3 yo truck. Well...chasing the wire harness, I found a section of the harness that had been rubbing against the rear right upper control arm; exposed and corroded copper. It's very in accessible to work on, so I'm taking the truck to my buddies shop to get it up on the lift. I hope to have resolve by this time tomorrow...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
Glad you found the culprit! Hope all is well now.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
It is now! It was the warn wire I found yesterday, wasn't easy to get to, but spliced & repaired! Put a small piece of rubber hose around the problem area to prevent it from happening agin!Ratkity said:Glad you found the culprit! Hope all is well now.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
Nice. It's always great to find the obviously correct fix, when previously it was a bunch of question-marks!
Wonder why it was free to rub on the suspension in the first place, on a TV so young. Aftermarket installation?Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
@4ncar, Glad to hear you got your mystery solved! I've used pieces of rubber hose slit down the center & placed on sharp pieces of metal to protect wiring & rubber hoses myself before. Nice simple solutions to avoid a not so nice situation later! Good thinkin'!
@ChanW, There have been several times I've asked myself the question..."Now WHY did they put it there, so close to THAT????"
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
For wire wear issues, I usually stick a high temp repair tape between the place and the wire and use heat-shrink splicers. Glad you found the rogue wire!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
So it was part of a bundle. That's tricky to find, and tricky to fix!
A_Little_T@b'll_Do_Ya0
