Electricity question and Cover question
lindab1256tabforum
Member Posts: 2
On the control panel where it has HEATING WITH ELECTRICITY there is a 1KW and a 2KW selection. When should I use 1 and when should I use 2. (I'm new at this and not very mechanically minded.)
Where can I get a cover for the TAB Outback? I see them for TAGS. Will that work? THANKS!
The alde has 2 heating elements(electrical), 1 is low, and 2 is high. Use one if you do not intend to use the hotwater/ right away & 2 if you want to heat it up quick(er). If the # 2 isn't enough, you can even fire up the propane along with the electric for even faster heating of the unit.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Be careful to pick the proper size.
http://www.walmart.com/ip/Classic-Accessories-PolyPro-3-Teardrop-Trailer-Storage-RV-Cover/54188560
- Hash T@B Fun
- 919 Introductions
