Passwords
It is most likely user error but every time a try to login I have to reset my password. Is this normal?
Thanks
Jon and Leslie Richey
2018 T@B 400. TV 2016 4 Runner
Minneapolis,MN
    @ JonNLeslie, this is not normal. I've checked your profile settings and can't see any particular reason why this should be happening.
    Maybe Mike or Verna have some additional insights.
  • jgram2
    jgram2 Member Posts: 1,522
    edited November 2017
    @JonNLeslie 1. Are you using an iPad? 2. Are you logging in via http://tab-rv.vanillaforums.com/ ? I had that problem when logging into the forum via the LG site. It was resolved when I used the Vanilla forum site. YRMV.
  • JonNLeslie
    JonNLeslie Member Posts: 20
    I am using an IPad 2 and I am loging into the nuCamp forum. I just keep reusing my same password when I reset the password.
    Minneapolis,MN
  • jgram2
    @JonNLeslie I'm a little computer challenged, so bear with me here. It might be worth the effort to try logging in via the Vanilla forums as mentioned above. My repeated requests for password troubles were resolved when I stopped trying to login via the old LG T@B site and came at it from the Vanilla site as suggested by several other forum members at the time. I don't know why. If I misunderstand your process, my apologies!
  • Michigan_Mike
    What are you using as a browser?   If you are using Safari, try switching over to Chrome and see if that helps.
    Or....  try accessing the forum via http://tab-rv.vanillaforums.com instead of http://tabforum.nucamprv.com
  • JonNLeslie
    Thank you it worked. I changed to tab-rv.vanillaforums.com. No more resetting
    Minneapolis,MN
