Norcold Fridge not working on Shore Power
My Fridge works on Propane and DC. I’m still troubleshooting. I think it’s something as simple as a fuse or the switch or a loose connection. Either way I set to take off for a month and may not have much opportunity to tinker with this if it’s any more complicated that minor diagnosis will indicate.
Heres my question to the smart electrical types on here. If I operate the fridge on the DC setting and have shore power connected, will that work?
Would recharging from shore power keep pace with the draw down on the battery from the fridge? I figure I can just try this and see but thought it’s worth asking the crowd first.
thanks for any thoughts on this.
Josh Orth.
Certified RV Technician
jomrvt.com
2021 T@B 320 CS-S
  • mona
    mona Member Posts: 246
    Make sure it's plugged in. Outlet is on the inside of under sink cabinet.
    jeannie
  • Ratkity
    Ratkity Member Posts: 3,770
    That sneaky plug just wiggles out of the socket sometimes!
  • blackoaktree
    blackoaktree Member Posts: 23
    Thanks I did all the standard checks. I check the outlet and I even plugged the fridge into a house outlet. It’s definitely an issue in the fridge.
    Josh Orth.
    jomrvt.com
    2021 T@B 320 CS-S
  • ChanW
    ChanW Member Posts: 3,171
    The 12v mode draws 11A or so, if I recall right. I think that might be tough on your converter, for any length of time. It also is constantly ON in 12v mode, and will freeze your veggies! (Fridge thermostat is only functional in 110v mode or propane mode)
    Why not use propane? It ought to last a good long while (weeks, if I recall @Verna's experience)...
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Verna
    Verna Member Posts: 6,876
    Yes, in this weather (Midwest), using the propane only for your fridge, the 20 lb tank should last two to four weeks.
  • blackoaktree
    Perfect solution! I’ll use propane. Not sure why I didn’t think of that one. Thanks!
    I’ll be in Tucson in December at a KOA so it’ll be easy to refill regardless of how long it lasts. I don’t expect I’ll need the propane for heat.
    Josh Orth.
    jomrvt.com
    2021 T@B 320 CS-S
  • Verna
    If you’re at a KOA, you can use electric for the Alde heat.  It does get cool as soon as the sun goes down.
