Hey there,
I have a 2015 TAB 320 S. The battery I have is a deep cycle which has:
- 1500 Pulse crank amps, 1010 marine crank amps, 76 amp hours, 160 minute reserve capacity
I realize it depends on how much I use however I'm wondering how long it will last if I only use the LED lights and put the fridge on propane. I will have water at the site and NO electricity. I also need to make sure I don't run my battery down too low and I'm unsure of how long that would take?
Thanks!
P
but it’s a good start.
I don't mean to add more complication but don't forget that as your battery draws down required amperage actually goes up. The lower the voltage the more amperage you need to do the same work. When I do my own calculations, I add 10%. That makes it easier and account for other losses too.
WilliamA
2017 T@G XL
When I first got my T@B, I did a test to find as many sources of parasitic draw as possible. Two "big" ones were the Jensen entertainment center and the television. I installed an inexpensive 12V rocker switch to turn off the Jensen, and simply pull the power plug from the television when not in use.
Thanks!
TV: 2012 Honda Ridgeline
Alice
Crozet, VA
2017 T@G XL
The blue display can be turned off using the two buttons on the left of the display
Alan & Patty
Southern Az
2017 T@G XL
@bikegirl...I say 2-3 days. Do you have one of those cigarette plug volt meters?
J.D. & Sue
Alice
Crozet, VA
