Alde question
Frost772
Member Posts: 11
i turned on my Alde system to test out the hot water, worked great. The next morning I turned it on for heating and it made a gurgle sound behind the toilet. Once I turned it off, the noise quit. Why did it gurgle??
2017 T@B CS-S silver with silver trim ("T@Boo') pulled by a 2015 Subaru Outback (6 cyl)
AT GA-ME 2000
@Frost772, The gurgle noise you're hearing is the glychol circulating from the reservoir. Pretty sure your reservoir is located in the "cubby" behind the toilet. (either that, or check fer a stranger in yer bathroom!
) 2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
Frost772, check the setting on your Alde pump. You can locate it under the driver side bench. It should be somewhere between 1-2. If set too high, it causes the glycol to circulate faster, may bubble more in the glycol reservoir in the hatch behind the toilet and cause the noise you heard.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Personally, I think the gurgling sounds more like a babbling brook, and it’s a nice sound to go to sleep to. Music to my ears knowing I’ll be warm.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”3
