2018 Change to gray/black water draining
Hello there!  Let me start by saying please excuse my lack of knowledge of proper terms - I am a premie-newbie!!  :)   I haven't heard anyone talk about the gray/black water change to the new T@B 2018 models.  From what I understand, the change is that the gray water is now flushed through the same hose as the black water, as shown in picture.  I guess the benefit is so that the sewer hose is rinsed out with other water.  Is this a beneficial change?  Pros/Cons?  Thanks for any input!
Lisa (will be a T@B owner in the next couple of weeks!!)
    pthomas745 Administrator, Moderator Posts: 4,669
    The major advantage (to my mind) is you only need to connect and disconnect your sewer hose one time each.  Those of us with two outlets (black/gray) need to connect to black, then dump, disconnect from black, attach to gray, dump.
  • lisaeggert
    lisaeggert Member Posts: 8
    Thank you, pthomas745!  That is all I need to know..... I will be going with the 2018 model!!  The fewer times I have to touch the stinky hose, the better!!!  lol
  • rkj__
    rkj__ Member Posts: 641
    I like the 2018 setup much better.  As indicated by pthomas745, it saves a step.
    Any trailer I have seen at the dump station has only one outlet, with both the black and gray routed to it.
  • ericnliz
    ericnliz Member Posts: 4,437
    edited January 2018
    @lisaeggert, We were one of the lucky ones to get the @Dalehelman special single dump installed. We kinda made a little impromptu T@B party out of it one day. There were two of us ( @ericnliz, & @Homebodyatheart) that gained from the experience. I only had to dump once with the dual black/gray tank outlets, & believe me it's MUCH cleaner & easier with just one! Thanks again @Dalehelman!!!! :)
    I'm pretty sure that was one of the things nuCamp listened to from current owners when asked about what improvements should be made to the new 400 model & the newer 320 models! Our experiences...your gain! :triumph:
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
  • Dalehelman
    Thanks Eric here Is a picture of our mod.
    1. Hash  T@B Fun
  • Jellybones11
    Jellybones11 Member Posts: 27
    Dalehelman that's they type of set up I am looking for. I have an aluminum utility tray with the tub and it's really difficult getting to the connectors without being a "Twister" expert. I also have neck problems which hurts when I have to contort to reach the connectors. Can I get this type of a Y connector anywhere or did you make it? Is it one or two pieces?
  • Dalehelman
    Here is a complete parts list less the clear extension.
    Here is a list of all the parts needed. You will be reusing both gate valves. Once you have all of the parts assembly is fairly straightforward from the above pictures.  The 22 1/2* elbow address's the frame clearance issue. The rubber elbow is not a perfect fit but that is why it is rubber. Once completed the discharge end is know lower than the original gray water discharge. I have found that the prices  for the RV parts are are cheaper at my local RV parts store.
    3" abs 22 1/2 degree elbow HD  $9.24 AMZN  $7.68
    3" abs 90 degree elbow with an 1 1/2 take out  HD   $12.43
      (3 in. x 3 in. x 1-1/2 in. ABS DWV 90 Degree Hub x Hub x Hub Elbow with Low Heel)
    1 1/2" rubber elbow with hose clamps HD  $6.84
    2ea. 3"  diameter x 2" wide black abs pipe. HD   $7.75 for 2’
    Small can of abs cement  HD   $4.88 8oz AMZN  $3.55 4oz
    Total $41.14     $35.36 (w/ 2 HD)
    RV PARTS STORE (For the gate valves)
    3" bayonet slip fit   AMZN   $6.88
    3" bristol spigot end AMZN   $7.75
    1 1/2 Bristol spigot end AMZN   $5.06
        Total $19.69
    Total for parts     $60.83 Total $55.05
    1. Hash  T@B Fun
  • dsatwork
    dsatwork Member Posts: 744
    edited April 2025
    @Jellybones11 There are several tutorials on how several of us tweeked @Dalehelman design to accommodate different  year models 2015 has slightly different clearances then 2017 models. This is one of the main threads http://tab-rv.vanillacommunity.com/discussion/3453/single-black-gray-water-drain-setup/p1    http://tab-rv.vanillacommunity.com/discussion/4140/single-waste-discharge-for-the-outback Even back in the day some hacks were discussed. http://tab-rv.vanillacommunity.com/discussion/comment/13938#Comment_13938
  • Jellybones11
    Thanks
  • Spectre9
    Spectre9 Member Posts: 40
    I also have a 2018 tab. Any feedback on black tank flushing through the unified factory outlet?  Particular device advice?
  • atlasb
    atlasb Member Posts: 584
    The common thought in the RV community seems to be to dump the Black tank first then dump the gray tank.  This helps to clean some of the Black residue from the hose.  Also a lot of people will flush the slinky hose before the put it up. On the 400, NU Camp gave us a port to hook a hose up and flush the tank.  We like having the clear plastic tube in line as it allows you to see when the water is running clear.  We carry a box of the latex DR. Gloves when working with the drain lines.
  • Homebodyatheart
    @Spectre9 are you asking about rinsing the tanks? If so, here's a pic of another @Dalehelman mod that I've modified and is working well. No idea if it's "perfect" as I can't see inside both tanks, but it's a lot easier than running in and out of the trailer dumping a bucket of water down drains after you dump. The piece of pipe insulation is only about 2” long, and glued in. Dale had warned me that there can be some backflow as you add water from the dump station fresh water hose, so this is my mod to his mod.  =)
  • Homebodyatheart
    @Spectre9 someone suggested once to  put water in your grey and black tanks and then you can practice dumping when they’re clean. You can just water your lawn. You’ve got lots of tank treatment options. I’m a Happy Campers powder user. Second year of use and still no odors, including the dump hose. I order tye small jar through Amazon. Lightweight and simple to store and use.
  • Fergie
    Fergie Member Posts: 143
    Speaking of modifications to the grey/black water valves, there was a discussion on breakage of same in a comment thread last November:
    https://tab-rv.vanillacommunity.com/discussion/comment/82821#Comment_82821
    In this thread we discussed having run over a tire tread that damaged our valves on our trip to Alaska last summer and having to have it repaired in South Dakota by a mobil RV repairman.
     I mentioned there and still feel it would be good to protect these valves with some sort of guard from road debris as, unlike most RV's, the T@B valves are very low and at the front of the trailer. I haven't done anything about this yet, but I have been thinking about some sort of deflector guard attached to the frame and extending in front of the covers, but not interfering with hose attachment.
    Wonder if any other owners have thought or done something about this exposure?
    Fergie
