Keder rail
judymac
Member Posts: 403
I think I saw a suggestion of greasing the rail to enable attaching screened room and reattaching the black trim easier. I haven't been able to find it via search feature.
Suggestions?
Thank you. Judy
Suggestions?
Thank you. Judy
Judy and Mike - Central KY
2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
I stashed the trim away so it can be reinserted to make it look good for resale. It does add that little touch.
Thank you. I think the cold temp made it harder to slide back in.Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
I applied a very small amount of dishwashing liquid to a cotton rag and ran it along the cord of my PahaQue awning before inserting it into the Keder rail. It worked like a charm and slid in very easily.Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
My dad used to use bees wax when he needed to slide things like this in - regular wax or wax for skis might work also.
The rail on my 2013 had sharp points on each end. I took a fine small file and rounded these sharp points. This helped and minimized the chance of tearing the material and helped it slide in easier. Sandra's silicon spray really helps also.Jim, Kelseyville CA, 2013 T@B "Q", T@BCASA, Silver W/Yellow trim, TV: 2006 Honda Ridgeline
I just bent the ends slightly and use silicon spray on a routine basis.
Saw these on another site and thought someone may find helpful to make your own awnings...cheaply.
The nylon spacers work better and come precut.
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
