2018 TAB 400 Drains
ChaseTheLight
Member Posts: 48
New owner here...Bought in December and was winterized. Should have shot video with my phone. Anyone help with where these drains originate? Photo taken from outside through the access panel - Aldi bypass is also in this opening. I am planning the de-winterization and making some notes. Thanks all.
2018T@B 400. Ford Explorer TV. Medina, Ohio
My guess one blue is main cold water drain other center blue is alde cold drain and red is main hot water drain. These are next to alde under bed next to outside service door if I am right.
2018 T@B 400, 2017 Nissan Titan Crew cab -
And the yellow one in the back is the water heater.
There's some discussion in this thread about the functions of the different drains.
Thanks for the responses- appreciated. After re-reviewing the thread mentioned by ScottG, there doesn’t appear to be consensus. Add to that the fact there is no current owners manual adds to the frustration. I sent an info request to Nucamp via their website today but there is no opportunity to attach a photo with the question. I hope they are working on a manual - that has been alluded in other threads.2018T@B 400. Ford Explorer TV. Medina, Ohio
@ChaseTheLight Did you get a flash drive in your owners' packet? I thought there was some kind of manual on that.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Yes, you should have received a flash drive and it includes all the manuals-mine also included the 400. It will say 2017. When I've asked NuCamp about a 2018, they told me it's in edit but they don't update the manuals every year...I don't see the 400 manual on their website either. If you can't find yours, let me know and I'll try to upload the file here.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S -
Thanks - yes I did receive the 2017 manual-dated 4/17. It isn’t clear which line drains what. For example, I know you can use the Alde to heat in winter as long as there is no antifreeze solution in the boiler. Would like to label each line to know.2018T@B 400. Ford Explorer TV. Medina, Ohio
- 919 Introductions
