T@B 400 Inverter Question
2014 Toyota 4Runner
youtube.com/c/travelswithdelaney
Hi, if no one is able to answer your question, you might want to reach out to the factory. They are usually pretty helpful with things like this.
I may do that. Thank you.2018 T@B 400
2014 Toyota 4Runner
youtube.com/c/travelswithdelaney0 -
I did call the factory and they said that they do not ground the actual inverter.2018 T@B 400
2014 Toyota 4Runner
I am thinking I need an inverter for when we do not have shore power? Should I consider the factory one? (Our T@B 400 is still at the dealer.) or purchase a third party one. I am concerned about the quality of the output for sensitive electronics.T@B 400 2018 Tacoma TRD SR50
FYI: In my 400, built 11/2017 - a Pure sine inverter was installed at the factory. Part # PWRIX120012S. 1200W Continuous/2400 Surge. (This model is available online for around $170 plus the optional remote should be bought ($30 and fuse holder ($7)
Now I really haven't had the need to use it yet camping, but I have tested it out on a small 700W microwave and voltage plug tester does show an open ground indication.Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
I just learned something
What NuCamp installed for my inverter appears not to be UL458 certified.UL1741 vs. UL458
Inverters—both batteryless and battery-based—used in residential-scale RE systems must be listed to UL1741, as required by the National Electrical Code. Inverters listed to UL458 are designed for mobile use—for example, on boats and RVs, which are sometimes off-grid and sometimes connected to a power grid (for battery charging and to supply supplemental energy for AC loads, but not for selling energy back to the grid).
The two UL standards differ in how they handle AC system grounding: UL1741-listed inverters must allow for the neutral-to-ground bond to only occur at the main AC service panel. UL458-listed inverters have internal neutral-to-ground switching relays to allow for this bond to occur at the inverter if in off-grid mode, OR at the utility power service if it is connected to a utility hookup. Some inverters are listed under both standards, so you’ll need to read the installation instructions carefully. Many Internet sources market off-grid inverters as “UL-listed,” but don’t clarify the actual listing, so they may not be appropriate for residential use.
This may answer the grounding question.
Utah Driven
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
