Kia Sorento Air Lift or Sumo Springs
Bicoastal
Member Posts: 16
Hi, for those who have upgraded their Kia to help with the factory soft rear springs, which did you install and did they really help? I’m not concerned about the lower tongue/hitch but more the extra bounce with the T@b is hitched. It’s not awful but would like to improve the ride if possible. Thanks
Question, how heavy os your tongue in travel mode?2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
Around 225 give or take when I shift thing around. I have 320 s Outback.
2017 T@b 320 S
2017 Kia Sorento SXL AWD
Thanks, I did see this thread. That’s what got me asking. One liked the sumo, one the Air Lift and one added lift springs. Just trying to see if one solution wins out.
Definitely talk to dsatwork. I took a different approach with my Sorento and used a weight distribution hitch.Bicoastal said:Thanks, I did see this thread. That’s what got me asking. One liked the sumo, one the Air Lift and one added lift springs. Just trying to see if one solution wins out.2017 T@b 320 S
Did the hitch help with reducing the bounce?
Hmm, maybe a little. If you haven’t already, you could try a few things to help improve the ride. Increase the tongue weight even more (move the spare to the front, fill the fresh water tank). Try towing with the trailer’s nose slightly down.
2017 T@b 320 S
Thanks for your help!
@Bicoastal Just saw this post and thought I would chime in. I used the Sumo Springs and they did help, definitely takes the bounce out and at 225 lbs might be enough. I run over 325 lbs tongue weight and wanted more support, which is why I pulled the SumoSprings and went with the Air Lift coil spring supports. There aren't any leaf springs on the Sorento, so I don't know how that would work.
I still have the SumoSprings cut and ready to install for $50 plus shipping they are yours for the taking.
Private message me if your interested.
2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle. -
Thanks for your response. I think I’m good for now.
- 915 Tips & Tricks
