Front window disappears (blew off)? While driving
sbhtennis
sbhtennis Member Posts: 69
We stopped at roadside viewing some elk when I noticed the whole front window was missing
We had been driving for about 60 minutes on the highway and never heard or saw anything to indicate a problem
I can’t say with 100% certainty that it had been all the way latched It’s a 2016 T@B Max S
Any ideas? I have read that some people have had some window problems or is the cause more likely an unlatched window?
We have put plastic over it till I get home to repair
  • Haloo
    Haloo Member Posts: 137
    edited April 2018
    If the top flanges of the window aren’t completely mated the window can fall off. Took me a little while to figure out why the front window on my 400 kept falling off when I opened it.  Tried to slide the window flanges together and it didn’t work. I was able to fit the flanges together completely with a rubber mallet.
    So yes, I believe that if you had it locked shut, it could still fall off.
    T@B 400 | F150 | Washington State
  • robpt
    robpt Member Posts: 90
    @Haloo, could you provide a pic of what you're referring to? I can't quite picture it and it sounds like a pretty serious issue, especially for whoever is driving behind you.
    Are you talking about the hinge to the window?
    North Florida T@B 400 towed by a 2014 Nissan Frontier
  • Homebodyatheart
    Homebodyatheart Member Posts: 2,516
    @Haloo If it wasn’t latched closed you wouldn’t be the first to have a window come off while driving. It’s been a while since someone has posted this issue, but it’s been known to happen. You can buy a replacement window and fittings from Elsie at NuCamp.
  • sbhtennis
    Will update when we get home
  • Haloo
    edited April 2018
    Yes, the hinge at the top. Basically the hinge is two curved plastic pieces with one slipped inside the other. Everytime I tried to lock the window open when parked, it would fall off.  It came from the factory with this problem. I kept thinking I had the hinge parts re-mated, but it would come apart again. Finally realized it could appear to be fitted together properly, but not actually be so. Used a rubber mallet to knock the parts together. No more problem.
    I'm on the road traveling right now. If I get a chance to take a usueful pic I will.
  • Haloo
    Didn't lose our window, but @sbhtennis did. I was suggesting that even with the window fully latched, it might still be possible for it to come off if the hinge parts at the top aren't fully mated. I fixed ours before it fell off while driving.
  • sbhtennis
    It’s now at the RV dealer
    I don’t recall what the hinge looked like
    There were 4 latches
    Two on the side and 2 at the bottom
    The bottom ones had a little button to press to get it completely closed
    Will look at hinge better when I get the T@B back
