How Do I Reinstall Alde Mixing Valve That Blew Apart
While adjusting the Alde mixing valve, I guess I went too far and the valve blew apart.  I now have the knob, a spring, and a brass piece that fits the knob.  Is this fixable by myself or do I need to go to the dealer?
2018 T@B 400 - 2017 Chevy Colorado
  • newbie
    newbie Member Posts: 30
    I should mention that this is on a T@B 400.
  • Verna
    Verna Member Posts: 6,876
    edited May 2018
    Elsie in Parts at nüCamp will have a good answer for you.
    ScottG Administrator Posts: 5,669
    edited May 2018
    Assuming you didn't force anything and all you did was unscrew it to the point of disassembly, then--provided you have all the parts that came off--simply screwing it back together is probably all you need to do. At this point, it can't hurt much to give it a try!  :-)
    However, I'm a little surprised there isn't a stop of some sort to prevent over-winding the valve.
  • newbie
    Yes, I had a ll the parts and took it back to the dealer to reinstall it.  We adjusted the hot water temp while I was there and it seems better now.
