Glycol level in my 2017 T@B 320S
I have read in this Forum that glycol level "should be just above MIN line".
Mine is near the MAX line. How do I remove glycol?  Should I remove any? Why have a MIN/ Max marking that does not apply?
    MuttonChops Member Posts: 1,973
    IMHO, short answer is don't Worry About It.
    'TANK' is an expansion tank like on your car radiator which includes an overflow tube/drain. So you cannot damage the system with a high fluid level, it will just overflow/drain off (to ground) when hot enough to expand.
    My Feburary 2018 320S built unit has the fluid level ABOVE tank marked maximum level.  Am assuming tank was filled at the factory not by dealer.
    My Alde system is working great with this high level.  Overflow tube does have some fluid in it so expansion has happened.
    Alde manual says fluid cold level should be 1-cm above minimum line when filling a low fluid level system.
