J.D. & Sue
Brann spank'n newChanW said:I'm surprised too.
RAD, is this Tab is factory new, or has it seen some miles?
Good advice to look over everything every so often.
Also be sure the hitch assembly fasteners are all secure on the Towing Vehicle.
Yikes.
That sure could explain it. Looking at the remaining fastener it really appears to be undersized in regards to diameter and way to long for the application. Looks like someone just grabbed whatever fasteners were handy.bigmatt said:I am pretty sure the propane tank mount and front battery compartment are installed by the dealer,results will vary. Thanks for the heads up,I will be taking a look at mine once this snow clears. Matt
leenscottfl said:Something else you may want to check. I removed my spare tire from down under and discovered that the nuts holding the tire were not 3/4 inch like my lug nuts. Don't know what they were but not a size I would take a a socket when travelling.
Sandra said:I'm not sure how the Little Guy T@Bs have their propane tank held in place - but the Dutchmen T@Bs have two hooked metal "wires" with wing nuts on the bottom of them. I periodically need to check to see that the wing nuts are still snug - or even attached. They just vibrate loose. Same with all the screws inside the T@B - just check to see that they are still secure.
So, in preparation for camping season, I took Sandra's advice and began the process of checking for loose screws on the T@B today. I counted 112 screws (I'm just that kinda guy) on the outside of the trailer that hold on trim and fixtures. Most of them were somewhat loose after one year of traveling. I have not started an inspection of the inside or any bolts, etc. underneath, but I suspect I will find the same there.
WARNING: Remember that these trim screws are anchored in aluminum and/or fiberglas. They should be snugged, but NOT tightened. Otherwise, you are likely to strip the threads. This is probably the reason they work loose. I found two that had already been stripped on the piece that holds the door open. Little Guy was wise enough to caulk most of these trim pieces, which helps hold them in place.
