Increase air flow for early 3 way fridges
Dalehelman
Member Posts: 2,414
- Hash T@B Fun
6
Does that run the risk of carbon monoxide venting back into the trailer when on propane?2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
No all exhaust gases exit through round vents on front of trailer. This just allows more air movement to improved heat dissipation under counter top. It should improve efficiency with less stress on the fridge.RollingBnB said:Does that run the risk of carbon monoxide venting back into the trailer when on propane?- Hash T@B Fun
2 -
@RollingBnB, I have to agree with @Dalehelman. If you have ever taken the stove top off, you'll see there are two hoses attached to the front vents that take all the exhaust gases out of that compartment. Nice job on that mod @Dalehelman. We just talked about that yesterday.
Where did you get that grate, and what did you use to cut that cover? Glued in, screwed in, or otherwise attached?
That should give that area quite a bit more ventilation, as the fridge fins sit almost directly behind that cover. Nicely done. Let me know what the materials are, and how you feel it helps. I've found even with the upgraded auxiliary fan the counter top still gets quite hot, especially in the summer heat.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
@ericnliz
I cut the hole with one of these
https://www.harborfreight.com/variable-speed-oscillating-multi-tool-63111.html
The metal screen was from Home Depot. I secured it with RV Goop from Walmart.- Hash T@B Fun
The propane flame for the frig is enclosed in two boxes (don't ask how I know) and the venting is through hoses that run to the outside. That is an amazing job! Love the pattern too.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
Before some eagle eye comments. The metal screen is straight. It’s the cameraman that’s crooked.
- Hash T@B Fun
5 -
@Dalehelman, As long as you don't leave any DNA behind, no one will ever know!
Thanks for the info Dale!
Eric aka: Lone Wolf0 -
Great idea! I was looking at this too this weekend. We were having trouble keeping the fridge cool on propane. First problem I noticed was that a couple of tags on the power lines had slipped down right on top of the internal fan. I removed those and this allowed better flow but still not enough. every time I pulled that cover off, the little fin cooling fan was running. After I removed the cover, the fan rarely came on. I figured It would be wise to vent that cover too. Then, I had an even better idea. I'm going to put a small computer fan on the cover and use it to push the heat out in to the camper to see if it will supplement the ALDE on really cold nights. I'll put it on a 3 way switch so I can either have it operate all the time or along side the internal fan or just turn it off to save power.2014 T@b S Max AKA T@dpole1
Nope. Mine was built before this was added. I will be adding that very soon. Just need to order the fans and draw up and print the fans mount. I know the factory sells one, but I can make one for much less.Dalehelman said:@ChrisK
Do you have the exhaust fan in the vent behind the door?2014 T@b S Max AKA T@dpole0 -
@ChrisK
The factory use to provide the fan, switch, and instruction up grade free. All you had to do was call.- Hash T@B Fun
I didn't know that. I'll give them a call tomorrow. Thanks!2014 T@b S Max AKA T@dpole0
Nice mod @Dalehelman!
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Bingo! Called NuCamp and they are sending me out the kit for free. Thanks for the info!!!2014 T@b S Max AKA T@dpole4
@ChrisK, Made me smile! Nu Camp is awesome & I'm more impressed with their customer service/satisfaction every time I hear a story like yours!
And, you're welcome. Glad to help.
What year were the fans installed? Mine is a 2016 320 S.
2016 T@B 320 S
2018 Honda Ridgeline
North Dakota
Mid production year of the 2016’sVerna, Columbus, IN
I guess I'll need to call and get info using the VIN. (I have to store the T@B off site). Thanks
2016 T@B 320 S
North Dakota
@Dalehelman this mod really works well. I'm doing some testing on the fridge with regards to some mods I'm doing. Its about 100 outside and I've got the fridge on 110v and the vent fan on. I was getting about 49 degrees in the fridge. I removed that front panel and the temp dropped down to 44 within an hour. I'm going to design and print a vent cover for it and cut the front out like you did.2014 T@b S Max AKA T@dpole2
I have 4 of them. I love tinkering.2014 T@b S Max AKA T@dpole2
Dale: not only is it functional, it looks cool. Is that a picture in a frame on the fridge door?Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)0
- 129 Dutchman and Vintage TaB Archives
