Bike Rack
Looking for a simple quick bike rack idea that doesn't cause me to give up the storage box I have installed in front of the propane tank bin on the tongue.
Here is what I was thinking: https://www.connorusa.com/products/1625370
I realize this would not give me access to my car when towing, but I can live with that.
Mickey & Terri
2016 Max S
Kalamazoo Michigan
  • DenisP
    DenisP Member Posts: 542
    I installed a Jack-it on our 400. Works well with minor modifications.
    2013 Tundra TRD 5.7L
    Massachusetts
  • Homebodyatheart
    Homebodyatheart Member Posts: 2,516
    I’ve wondered about this setup, too. Thanks for asking this!
  • mandt
    mandt Member Posts: 158
    This may even be a better idea?? Less parts... less wiggles...
    https://www.harborfreight.com/multi-use-ball-mount-66966.html
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
  • Boulderjay
    Boulderjay Member Posts: 37
    I really like this option... Get to use my old Thule bike rack too!  I beefed up the connections with a couple grade 8 bolts through the frame with nylon lock washers. $167 on Amazon Prime
    Stromberg Carlson CC-275 Bike Bunk... https://www.amazon.com/dp/B00KQPLJVI?ref=yo_pop_ma_swf
  • DenisP
    Jack-it on my 400
    Massachusetts
  • mandt
    Both of those racks look like they would work well, but I am hoping for something simpler, less tall, and easily removable because we often do not take our bikes. Does anyone see a problem using this:
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
  • Boulderjay
    Just make sure it gives you the turning radius you need and your bikes don't get pinched
  • Dereco
    Dereco Member Posts: 95
    We found this one to be ideal for us, it's a clamp carrier, clamps on to the receiver portion of the hitch. Works for 3 bikes, and we can take the bikes when we move in the TV without the trailer.
  • gooddogs74
    gooddogs74 Member Posts: 76
    We are going to buy a seasucker rack for ours.
    2018 T@b 400
  • scotty0424
    scotty0424 Member Posts: 17
    Is there a possibility of having a receiver welded to the frame at the rear of the trailer and moving the spare tire elsewhere?
  • Verna
    Verna Member Posts: 6,876
    No, the frame is not constructed to allow for this modification. Also, with the boomerang effect of a rear hitch, there is too great of a chance of losing your bike and or rack, as I did on my Silver Shadow Teardrop.
