exterior rubber molding
denlatham
Member Posts: 4
If your referring to the small rubber moulding attached to the colored trim piece, it is cosmetic only. It does not seal anything and should not be caulked.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az1 -
@denlatham Can you provide a photo?John, Judi, Guinness & OD in PDX
Alan & Patty
Southern Az1 -
I have a spot of molding by the left rear turn signal. Is that a caulking spot? If so, I'd probably use some clear caulk for it to be less visible...
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
That looked a lot like mine. I have some lifting on the front and some like that on the back. I found that Shoe Goo and Goop for RV are seemingly identical products and both act like rubber cement. Even though I was told by NuCamp the rubber is not supposed to be glued to the trailer (just the inside track piece holding it in), I was able to get the goop inside the back pieces, and lay flat, tape them with blue tape, and remove 24 hours later and it worked. They now lay flat, glued to the trailer. Unfortunately, that did not work on the front section. It is still lifted, but not out of the track. To apply caulking or anything inside there would require a pointy tip; it sure is a mess otherwise.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
