Winter Camping Approach
JanetED
Member Posts: 12
I am going camping in an area where the temperatures might get down to 25 degrees some nights. I am hoping that this approach will work. I am going to winterize the trailer (T@B Outback 2017) but I would like to use the back water holding tank. I have an external holding tank that I was going to empty the trailer tank into every afternoon then put a little antifreeze down my trailer tank. I am thinking that should protect the toilet valve and the gate value. I am not going for a few weeks and it might not be that cold, I just want to be prepared now for freezing temperatures. Any advice would be appreciated. Thank you
Janet
2017 T@B Outback
TV 2012 Nissan Frontier
Tehachapi, CA
2017 T@B Outback
Tehachapi, CA
1 suggestion I’ve seen re winterizing was to use a spray bottle full of RV antifreeze and spray the tank valves, opening and closing them a few times between sprays to ensure distribution. Although I’ve not done that, it seemed like a good idea.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner3 -
@JanetED another option that would be simpler is to make your own "litter box." Place two plastic bags, one inside the other, in the toilet. I also place something like a cottage cheese container lid over the dump opening to keep the bag bottom out of the antifreeze when winterized. Add two cups (give or take) of kitty litter. When you decide it's time, pull the inner bag out, tie a knot and put it in the trash. Add a new bag, kitty litter and you're good to go, so to speak. I use this when Ladybug is in storage so I'm not running back and forth to the house when needed. Handy and simple, and fairly inexpensive. Good luck!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red3
Thank you, I think I will make a litterbox. I never thought of that.Janet
2017 T@B Outback
Tehachapi, CA1 -
Never tried it, but I've read on other RV forums about plenty of folks who winterize then bring a few gallons of the antifreeze for flushing (when a public bathroom cannot be found). Seems doable too.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
Former steward of a 2017 T@B S Max1 -
Agree... We've used the plastic bags for early season camping. Works great Drinking water in jugs.2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN1
J.D. & Sue
