falcon1970 said:. . . determine where the fresh water tank or the gray tank is located. Does anyone know? Are they mounted under the floor between the frame rails?
Yes, black water tank is 'above the floor'.
Yes, fresh and grey tanks are 'below the floor'
This picture (chassis upside down during tank mounting) shows the Grey Tank {under red tool caddy} and the white Fresh Tank waiting to be installed.
https://tab-rv.vanillacommunity.com/discussion/comment/92705#Comment_92705
falcon1970 said:. . . base tongue weight is 390 lbs and the "wet" tongue weight is 400 lbs. What does the "wet" weight entail? Is it just a full fresh water tank or does it mean full fresh, black, and gray tanks? or something else entirely?
Comparing different NüCamp data sources found this:
