TAB 400 Tailights
falcon1970
Member Posts: 758
Has anyone had an opportunity to remove a taillight (the STT lights) on a TAB 400? How does the silver trim ring come off? I suspect there are plastic clips holding it on but how many are there and where are they?
I would call Austin Jones down at the NC repair shop as he will be able to help you out. I’m guessing that the tail light assembly is a sealed unit and will require some work to get it out. I would consult with Austin and am sure he can give you the best approach in removing the unit without damaging your trailer trim, the fixture, etc.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
- 917 Introductions
- 73 Teardrop Groups & Links
