Jack crank hits front rack.
stinkbug
Member Posts: 19
T@b Outback, on first use discovered leveling jack crank hits front aluminum rack to prevent deploying them with the crank.
Just a word from one who is in possession of very little useful knowledge. You refer to "leveling jack". I think you are referring to the stabilizers that should not be used for leveling. Sorry. Had to say it.Scott, Orange Park, Florida...2012 Jeep Wrangler Unlimited Sahara... 2015 T@B S Maxx "Buttercup".
I stand corrected. Thanks.
BTW, went to local trailer supply and bought a longer crank. Got home and it didn't fit the jack! They didn't ask about size and I had no idea there were different sizes on the screws that opperate the jacks. Here I go again, 50 mile round trip...
Check out RZRBUS' s post. He made his own in a very low tech way.Scott, Orange Park, Florida...2012 Jeep Wrangler Unlimited Sahara... 2015 T@B S Maxx "Buttercup".
I have the same issue. I read that you can get a 'socket' to put in your electric drill that will do the trick.
Bill from Los Angeles Arizona
2015 T@B S Maxx Outback
2020 Jeep Grand Cherokee Trailhawk -
I took the standard crank supplied with the T@B, hacksawed it in half, found a steel tube with ID the sames as the crank shaft OD and had it welded together at a muffler installation shop for $10. That made it long enough to reach the rear jacks without getting on your knees and crawling under the trailer.
2018 T@B Boondock Edition. 2008 GMC Sierra SLT Z71 4X4 5.3L V8. (2) BB 100Ah LiFePo4. Charlotte, NC -
I like innovative ideas (and people) that make tasks easier, well done and thanks for sharing! Excellent solution and I know that others have shared similar fixes for the stabilizers on the T@B units.Rollingztone said:I took the standard crank supplied with the T@B, hacksawed it in half, found a steel tube with ID the sames as the crank shaft OD and had it welded together at a muffler installation shop for $10. That made it long enough to reach the rear jacks without getting on your knees and crawling under the trailer.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ -
Before we left the Dealer I had them call Little Guy and they agreed to make and send us a longer crank. We'll see.
It is really easy to just cut it off and use a drill. zipp zipp. My neighbors were green with stablizer envy.The Mouse house and me
I use a cordless drill, too.Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA
Think I'll get a spare for hand cranking when the drill battery goes dead.
Check out Jack-up. Video on advertisement. It removes after hooked to TV. I. Love it and it prevents Handel from nitty tail gate. About $65.00 on Amazon.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
DeputyDog - You talking about the Jack-E-Up?
If so, I love mine too. Great little product. Especially if you have a swinging tailgate on your TV
- 917 Introductions
- 73 Teardrop Groups & Links
