took my LP tank off for the first time and installed a tank sensor on the bottom that measures how full your tank is-since I've only used it a few times for cooking it is pretty full\heavy-I had to take it off n on about 4 times because the sensor which is supposed to stay on with magnets kept slipping off center when I would turn the tank back over-I finally duct taped it in place and it was reading 100% full on my iPhone app-never could get my stove to light after-didn't seem like any gas was getting through-yes I opened the line-so turned off took apart n looked inside connection where uh-oh broken white plastic ring\washer -anybody know what it is called and where I could get one to replace-it is 3\4 inch across in diameter white ring fits under connection-i'am assuming that this is why not working-it must have to be there to make a seal?? I don't know if I broke it by tightening too tight?? or if it cracked from the cold weather-found the other half of it on the driveway underneath when I took it off the first time it didn't seem like it was on very tight
