OK, mine has three breakers instead of four.
30A Feed (Main)
15A Recept (Outlets except A/C)
20A A/C
Since I don't have the Alde, there is no fourth breaker?
It also has seven blade fuses: The first four are 10A, then a 20A and a 30A. Last is the 40A. I assume that the DC fuses are the same as above diagram.
It's a good thing I went out to check because I noticed that the third DC 10A fuse (for lights, etc.) only had one blade inserted in the slot. The other one was making contact but outside the slot at the bottom. I think I've had all these fuses out at one time or another checking them, so I plead guilty. Funny thing, it was so obvious. Don't know why I didn't notice it before.
Michigan_Mike said:I cleaned it up a bit and added the verbiage in and created a jpg file that you could copy and print out if need be..... Here you go!
