Ignition protection switch
Bobber
Member Posts: 16
There is a fuse and switch behind the battery cut off on the 2018 400. Does anyone know the purpose for this. And what position it should be in?
That is a 40 amp circuit breaker used instead of a fuse to protect your battery. If you are able to run your appliances off the battery, then the breaker is intact. If not, I would reset it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
The circuit breaker has tripped. Push the red lever under the cover so that the lever is under the cover and it should work. Pressing the red button on top will manually trip (open) the breaker for test or maintenance purposes. Those are very nice circuit breakers.T@B 320 manuals and electrical drawings
2023 Jeep Gladiator Sport S, Max Tow Package. -
Thanks @klenger. I was not sure of the “set” position.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 915 Tips & Tricks
