SeeLevel Display says “zero”
melpeter
Member Posts: 112
SeeLevel Display says “zero” on gray tank even after I did my laundry in the sink and washed dishes. That means it must be broken. The other monitors appear to be working. Without the gray tank monitor, even if inaccurate, is there a low tech way to tell when it’s getting full?
2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.
2014 Mazda CX 5
Sort of. The lowest drain is in the shower, so if water starts to pool in the shower pan, your tank is probably full!
Are you connected to camp ground water? If not, and you are using water from the fresh water tank, then you can get a pretty good idea of the holding tank levels by how much water you have used. It's possible that you have not used enough water to get past the empty sensor. Watch it over the next day or so. Also, if the trailer is out of level and the sensors are on the high side, then the tank level would read lower than expected.T@B 320 manuals and electrical drawings
2023 Jeep Gladiator Sport S, Max Tow Package.1 -
I’m connected to shore water. And level. I might have been a little cautious even so. I’ll give it another day or so and quit being stingy with water. Thanks.klenger said:Are you connected to camp ground water? If not, and you are using water from the fresh water tank, then you can get a pretty good idea of the holding tank levels by how much water you have used. It's possible that you have not used enough water to get past the empty sensor. Watch it over the next day or so. Also, if the trailer is out of level and the sensors are on the high side, then the tank level would read lower than expected.2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.0 -
It seems to take a couple days use for my gray and black tanks to register.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0
