Latch coming apart on plastic tub on 400
DenisP
Member Posts: 542
Just a heads up on a close call we had while on an extended trip with our 400. We had just left East Glacier and pulled off after a couple miles to assure we had secured everything. My DW noticed the tub lid was not locked, after a quick look the screw which holds the latch hook and the latch hook had fallen off. Luckily, I had put a lexan bottom on the tub which captured the loose parts. I reassembled the latch and tightened the screw. The fix worked for another 2500 miles when I noticed it was loosening up again. Bottom line is that the screw needs some medium hold Locktite. I would recommend that as a preventative measure that others do the same.
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
Good advice - thanks for the update. I think I might just keep a little Locktite in my truck.2019 T@B 400 BDL
PNW
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
