Peter & Darlene
"Sparky" 2019 T@B 400
2017 Honda Ridgeline RTL-T
Flagstaff, AZ
Odd Interior Clunking Sound...
Petroffski
Member Posts: 28
Howdy all!
I was in "Sparky" to start the process of getting it ready for our trip to the White Mountains here in AZ and while in the bathroom the trailer rocked a little, like it does, and noticed a clunk/knock behind the sink. If I intentionally rock from side to side there is a considerable clunking that will continue until what ever energy it is has built up wanes. It's "definitely" something swinging. I can feel it against the outside wall. Inside the bathroom it has a slight hollow metallic sound to it. I'm not especially concerned about it but am VERY curious what could be behind the sink area that is loose. This is something new. Any ideas?
Thanks-
Peter
Thanks-
Peter
I worked at an Oldsmobile dealership years ago and we had a new olds 98 with a rattle in the rear seat area. Opened up a trim panel, found a pop bottle with a note that read, " I see that you finally found the noise!" NU Camp doesn't build like Olds does and possibly the reason that Olds is no longer building.
2018 T@B 400, 2017 Nissan Titan Crew cab -
What model TaB?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Sorry. It would seem my overly designed signature isn't doing its's job. It's a 2019 T@b 400.Peter & Darlene
Flagstaff, AZ -
Here's a video link that doesn't quite show what it sounds like. https://www.icloud.com/sharedalbum/#B0N5oqs3qDGJ9TPeter & Darlene
Flagstaff, AZ -
Is it the metal shower hose?
The .sig is generally not visible to mobile users, so it's best to put "400" somewhere in the title.Jean & Arnie Nevada
2019 T@B 400 BL
2021 Toyota Sequoia 4WD -
No... the hose, in spite of appearance, was no closer than 3" from the sink.
Peter & Darlene
Flagstaff, AZ
