LED Puck Lights for Rear Outside Storage Compartment and Aluminum Tub
Bayliss
Member Posts: 1,517
I installed these inexpensive puck lights (uses 3 AAA batteries; not included) to light up the rear outside storage and aluminum tub. Very easy to install. I used two screws (included) to attach the storage compartment light to the 2 x 4 board just inside the door. I attached the aluminum tub light to the front inside center of the tub using 3M double-sided tape (included.) Although the tub is curved, it is close to being flat at that particular location, so the light attached nicely. The lights tap on/off and are surprisingly bright at 45 lumens. The lens portion twists off easily for battery replacement.
https://www.amazon.com/gp/product/B079WQT6QM/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
