What’s This Valve?
TNOutback
Member Posts: 633
2020 T@B 400 with the closet, looking into the area with the water pump. Anyone know what this inline valve is for here?
There is one on both blue and red lines, correct? I believe those are outdoor shower shut off valves. Try turning them 90 degrees and see if that kills supply to the outdoor shower.2019 T@B 400 Boondock Lite
I have confirmed with a bit of iPhone photography around the dark recesses that this set of valves are indeed for the outside shower. I’m so glad Nucamp has thought of this since the outside shower is one of my freezing concerns when winter camping. Now I know I can shut those off deep inside the camper and not worry about it. Well done, Nucamp!
Just remember to blow out those lines before you close the valves if you intend to do winter camping with the rest of the water system operational.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA -
or make sure you get RV antifreeze into the outdoor shower head and lines if you are using antifreeze to winterize. . ..2018 Tab 400
