Alde Leak Normal?
Tabaz
Member Posts: 2,420
With the Alde water heater full and the trailer raised all the way up on the tongue, water (not glycol) leaks from the rear bottom of the Alde unit. This happens in reverse when I lower the tongue all the way down- water will leak from the bottom front of the Alde unit. Is this normal because of the extreme angles?
2016 Outback 320
I would ask Spencer from Alde. There was someone not too long ago on the forum that had a water leak. Water collected in the pan under the Alde.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Never had that happen. Doesn’t sound normal. Have you checked the Alde compartment for leaking hoses or connections?
Jeannie2015 T@b S Max white with silver trim. 2018 GC Trailhawk.0 -
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thanks SiS - looks like the water is coming from the drip pan, just not out that little hole near the exhaust. I'll call Alde first thing tomorrow.2016 Outback 320
@Tabaz , yeah, as much as the whole condensation idea sounded right, it may be a leak. Good luck!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Condensate was my knee jerk thought...but alas, something else...?TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
Turns out the leak was just water that had accumulated in the drip pan. Have been testing it for several days and no more dripping front or back with the trailer in extreme angles. Whew!2016 Outback 320
2024 Ford F150 Supercrew short bed.2
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
