2020 T@B 400 non Factory Solar
DeanP
Member Posts: 14
I was recently looking at a number of different 2020 T@B 400s. Some with factory solar, some without. I noticed that the 400s with solar did not have an external Zamp connector and the ones that didn't have solar, did have external Zamp connector. And I guess that makes sense. My question is, how is the Zamp connector wiring terminated inside the trailer? Is there a charge controller at the end of the Zamp wiring?
2020 T@B 400 BDL
TV 2018 Toyota Tacoma TRD Sport 3.5L 4WD with Firestone air bags.
MODS: BMV-712 battery Monitor, MPPT 75/15 Charge Controller, Fantasic Fan PWM control
Central Ohio
Central Ohio
The charge controller is on the Zamp solar panel. The Zamp plug on the T@b is just wired to the battery. I added a Zamp port on my 2019 400 that had neither the factory solar, or a Zamp port.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA -
One issue I see from a technical standpoint is all panels with the charge controller at the panel is you have some DC line loss getting to the battery. If you are running 25-50 feet from the panel to the battery are they getting full voltage to the battery?2019 T@B 400 Boondock Lite
Thanks @Horigan @N7SHG_Ham. That's exactly what I was hoping to hear. We pick up our 2020 T@B 400 BDL this Thursday and that was one thing I forgot to ask about. I intent to have two 100W remote panels with 30 feet of extension cable and I'll install a Victron 75/15 MPPT SmartSolar charge controller in the trailer near the batteries. I'm going to add a Victron BMV-712 Battery monitor as well and I think we should be good to go.2020 T@B 400 BDL
Central Ohio
- 915 Tips & Tricks
