Installed
New 320S Owner - - early modifications/additions before the Shakedown Trip.
1. Mounted a Hopkins 09715 Hitch Level in front of the Jack post.Not a bad start . . . will be Shakedown
Trip ready soon.
Forum has been a wonderful place for
ideas and project how-to's.
Thanks to everyone.
White Tire Cover on Order.
Cable or Chain Lock to be Added
Do wish I was using SolidWorks. Used it at two different jobs. As a Manufacturing Engineer not a mechanical design engineer my drafting/modelling skill was down in the 1-2 range on a scale of 5.hymie said:... Are you using SolidWorks?
Yes, this is a permanent installation. Solar Panel can lay down flat for travel or even high noon.jkjenn said:Is your 10w panel permanently installed?
RogerL said:. . . What size u-bolts did you use and what is the red padding on them?
gbell said:Were did you purchase the attached 10 watt solar and 20w controller? Did the cable to the battery come with it?
Note: Controller is Not waterproof.
I mounted it on the bottom side of the tub lid
hoping to keep it dry.
Only wire that was included was a two conductor wire about 3-feet long connected to the solar panel. I purchased/made the controller to battery wire connections.
...except for the need on uneven terrain...BrianZ said:Nice mods, @MuttonChops!
Will have to add some of these to my "to do" list.
Now you've got me wondering if there is any reason not to permanently mount stabilizer pads & save all that backbending trying to position them.
Thanks for sharing.
