Tab 400 Tail lights: How do you access for maintenance?
rbrtm
Member Posts: 34
No screws.
@rbrtm You can access the 400’s taillights without a screwdriver?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Nope. All the plastic shrouds look like they're stuck down with something. No visible fasteners.
No access from inside the trailer that I can see.
Not sure, but I believe the tail lights are glued in with a sealer type sealant. There is a series of screws on the bottom where it joins the belly. the bulk of the rear panel is glued on also. Might connect the Tech guy at NU Camp I think there are several that can and will answer your question.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
