How long is the factory warranty on a new T@B?
Jdcouple
Member Posts: 96
How long is a factory warranty on a new T@B? My propane leak detector is beeping every 40 seconds. I just called the camper retailer and they told me I was out of factory warranty. We bought the camper in February of 2017. It's September 4th 2018. That's not even 2 years!
One year.
Check your battery voltage.John and Henrietta, Late 2016 T@B S Max in Western New York -
Will do. Dose any one know what the beep every 40 seconds means? It says it on the face but no explanation. The book is no better. I searched this and found people discussing it but no explanation for it.
As Photomom suggested, it is probably indicating low battery voltage. Did you try to reset it?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I tried to reset but no change. The battery cutoff switch was off for the last few months. The wife heard it a week ago and couldn't figure out what it was. I found it yesterday while prepping for an up coming camping trip. I cut the battery back on and I am going to go plug the camper up now to charge it. I'm hoping that will fix it.
What else could beep? The voltage is at 12.9. I hit the reset button while hearing the 5 sec beep we have been hearing and the it churped all the lights came on...... but the beep continued and is still happening. Lol
The smoke detector can chirp, I think.Jon & Angela | Florissant Colorado | 2017 Outback S
Low battery in the detector? Smoke alarms in a house wired to 110 have a battery and they beep when low even though you have 110. Could be same in the Tab.2019 T@B 400 Boondock Lite
Are you reporting voltage while plugged in? That will not be a resting voltage. What was the voltage before plugging in? If you did not check it, unplug now,, let it sit 30 min. Then check the voltage.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
FOUND IT! I'm not hitting on all cylinders this morning. I looked for the smoke alarm earlier and couldn't find it. It is in the corner by the AC box. Anyway. Crisis averted. Lol new 9volt is all I need. I feel dumb now. Lol
That was the resting voltage. It 13.3 plugged in.
Glad you found the culprit!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 917 Introductions
- 73 Teardrop Groups & Links
